tinaljmcgee
Jan 11, 2022Follower
What battery do I purchase for a MR1100?
I currently have a swollen battery, p/n 308-10077-01, in the Netgear. I'm trying to find a similar part number to purchase new, but I'm having trouble finding it. Can I use a battery with part numb...
JohnPeng
Jan 13, 2022NETGEAR Expert
Please buy from Netgear.com. But the battery is currently out of stock and may be re-stocked in Q1.
https://www.netgear.com/home/mobile-wifi/hotspots/mhbtr10/
Thanks
John
- nielsvdsJan 13, 2022Luminary
You can purchase a third party one:
https://www.amazon.com/Replacement-Battery-Netgear-Nighthawk-Hotspot/dp/B08FRQ5TR5
https://www.ebay.com/itm/184876056049
(the correct model is 1ICP4/54/72-2 to look for) You can find that information on the battery pictures that you can find on the netgear website.
