tinaljmcgee
Jan 11, 2022Follower
What battery do I purchase for a MR1100?
I currently have a swollen battery, p/n 308-10077-01, in the Netgear. I'm trying to find a similar part number to purchase new, but I'm having trouble finding it. Can I use a battery with part numb...
T4DCY
Mar 03, 2022Aspirant
Bonjour, for your MR1100 you can use 308-10019-01 or 308-10034-01.
If you want I have two brand new bought by mistake for my MR2100 but it does not work.
I need p/n 308-10077-01 that I am desesperatly looking for... or any p/n compatible?
If anyone can help?
Merci
