Xop0
Oct 22, 2023Star
What can I do with my NETGEAR Nighthawk M6 Pro (MR6450)?
Let me start with the fact that this is my second purchase of NetGear. Fortunately, I managed to return the 5th version within a month; it turned off within minutes. This device was purchased on June...
ch3wbucca
Mar 12, 2024Aspirant
Appreciate the update, but can we please get this expedited? We still have to pay our monthly subscriber fees to Telstra without being able to use the hardware to access the network.
Telstra and Netgear need to work together on this, and not simply say one party is waiting for another party to do something.
As others have pointed out, this is a premium product.
Please advise.
Thank you.
ch3wbucca
Also, mine isn't even a month old and it's been hot enough for the SIM card to curl up on either end!
- schumakuMar 12, 2024Guru - Experienced User
Undoubted, a hot device, with temperatures able to melt the PVC (or whatever alternate chlorine-free materials) SIM card carrier 8-/
- ramMuthanaMar 12, 2024Tutor
can you please help understand your setup, operating with battery or as fixed wireless without battery and FW.
the latest FW has few fixes and most people are happy that the device is not as hot as earlier.
you can please share your model.json in a private message to help us debug and serve you better
Thanks, Best Regards
Ram
- ch3wbuccaMar 14, 2024Aspirant
Running without battery. I'm not sure people would be happy with running hot enough to deform the SIM.
