vmarie
Oct 01, 2020Tutor
What is MYSIMPLELINK connected to my Router?
I have an unknown device showing in my Genie that is called MYSIMPLELINK and I would like to know if I should block it and if so, HOW? I have tried to block it, but it is still showing up.
SOL...
- Oct 01, 2020
I have a feeling its part of the ring doorbell.
https://community.blinkforhome.com/t/what-is-mysimplelink/8313
Ring and blink are both owned by amazon.
vmarie
Oct 01, 2020Tutor
Yes, but it shows on the device list as well.
Oct 01, 2020Guru - Experienced User
More than 1 camera or a sync module like blink has?
- vmarieOct 01, 2020Tutor
I only have a Ring doorbell.
- plemansOct 01, 2020Guru - Experienced User
okay, thanks! I will check out that link.
