RobotPirate
Nov 11, 2021Aspirant
What is the highest wattage I can use for charging my Netgear M1 hot spot?
It is an mr1100 ATT model I have an aftermarket Anker 18 watt but the device reboots sometimes Can I up the wattage for a chargeR?
- Nov 12, 2021
Yes. You can use the battery when plugged in. The device will reduce the charging voltage when detected the device is plugged in 7/24 in order to protect the battery. So when you see the battery is not fully charged after certain period of time, it is normal.
Thanks
RobotPirate
Nov 12, 2021Aspirant
Thank you!
Can I use the battery in the M1 even when plugged in?
JohnPeng
Nov 12, 2021NETGEAR Expert
Thanks
