JesseLee72's avatar
JesseLee72
Follower
Aug 02, 2020
What nighthawk MR1100 firmware do i need?
What firmware works best for Tmobile and what one works best for AT&T. Looking into buying the router and reading conflicting reviews about non compatible firmware and IMEIs.. thanks in advance.
1 Reply
  • michaelkenward's avatar
    michaelkenward
    You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
    You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
    Mobile Routers, Hotspots & Modems
    If you visit the support pages:
    Support | NETGEAR
    you can feed in your model number and find the documentation for your hardware.
    It will also have any firmware and drivers for your device.
