kisserik93
Apr 12, 2018Follower
Whch mobile router? NETGEAR AirCard AC790 vs NETGEAR AirCard 810
Hi,
I would like to buy a new Mobil Router, but I don't know which one is the best choise for me.
I have an unlimited mobile internet in Hungary, and it would be good if I could use the internet abilities.
I'm looking for a device that works properly, no big mistakes.
Do the two devices I mentioned (NETGEAR AirCard AC790 vs NETGEAR AirCard 810 ) have known defects?
Is it worth buying one? I used to hear that they did not work very well.
Can you give me help here?
Thank you
- JasonNNETGEAR Employee Retired
Hi kisserik93,
I would suggest checking with your ISP on which bands they are compatible with. As of defects I have not seen any defects.
Below, I have provided the data sheet and user manuals for both devices. From there you can see which device fits your needs.
AC790:
User Manual: http://www.downloads.netgear.com/files/aircard/AC790/AC790_UM.pdf
Data Sheet: http://www.downloads.netgear.com/files/GDC/datasheet/en/AC790.pdf
AC810:
User Manual: http://www.downloads.netgear.com/files/aircard/AC810_Retail/AC810_UM_EN.pdf
Data Sheet: http://www.downloads.netgear.com/files/GDC/datasheet/en/AC810.pdf
Please let me know if you have any other questions. :]
- Jason N
As I know, the Netgear AC790 and AC810 could both work in Europe area, including Hungary. But you must make sure the Aircard 790 and 810s are SIM unlocked.
Some of them may have defects, no product is perfect.
