DaForc3
Jul 01, 2017Follower
When are we getting NEW firmware for the Nighthawk M1?
The M1 is currently suffering from... Wireless stops responding Random reboots Battery sometimes refuses to charge Ethernet going to sleep Constant issues with usage meter Poor upload perfor...
- Nov 14, 2017
Hi Wiz_THS,
The current implementation on 10.16.04.04 (MR1) is as follows:
- MR1100 boots up and ethernet port is live for about 30 seconds
- If Ethernet port detects something plugged in it will remain active
- If Ethernet port detects nothing is plugged in it will disable the port to preserve battery life
We are investigating ways of keeping the ethernet port active whilst still trying to preserve battery life. These fixes could possibly be implemented in MR2 but not commited as yet.
Kind Regards,
ArodiD
DarrenM
Jul 10, 2017Sr. NETGEAR Moderator
We plan to fix the following issues in the next firmware update which is scheduled for release late July/ early Aug depending on Telstra certification.
Random reboots
Poor upload performance
DarrenM
- Wiz_THSAug 08, 2017Aspirant
Any updates as to when the firmware update for fixing the 'Ethernet going to sleep' will be released?
- MicWAug 08, 2017LuminaryApparently a new firmware came out yesterday. Though there is no information anywhere on what issues it addresses. You could try a manual check under Administration in settings and see if ti will update
- Wiz_THSAug 09, 2017Aspirant
My Netgear M1 is up to date and the Ethernet is still going to sleep :-(
Does anyone know an ETA to when this issue will be fixed?
