Alkhaldi_1
Feb 23, 2018Aspirant
When are we getting NEW firmware for the Nighthawk M1?
I have netgear mr1100 running on NTG9X50C_10.12.02.01 i cannot update it itried all method you could thing about by app some time it stuck in zero and somtimes error the strange thing my bro's has on...
JasonN
Mar 02, 2018NETGEAR Employee Retired
Hi Alkhaldi_1,
Just checking in on you and seeing if you had this issued resolved.
Please let me know. :]
- Jason N
Alkhaldi_1
Mar 02, 2018Aspirant
No still stuck on this damn update NTG9X50C_10.12.02.01
- JasonNMar 05, 2018NETGEAR Employee Retired
Hi Alkhaldi_1,
Thank you for your response. I will update you when I have any information from my internal team.
- Jason N
- JasonNMar 12, 2018NETGEAR Employee Retired
Hi Alkhaldi_1,
My internal team is asking if you have done a factory reset before trying to update the firmware. If not, Please proceed with those steps.
- Jason N
- JasonNMar 15, 2018NETGEAR Employee Retired
Hi Alkhaldi_1,
I just wanted to check in with you and see if your proceeded with the step I provided.
- Jason N
- PepitoBirdApr 04, 2018Aspirant
Our company bought two Nighthawk M1 units from Telstra, both had old firmware with the ethernet standby issue.
One unit upgraded to the current firmware online find but the other is stuck on 10.16.04.04 and refuses to update ... tried everything including soft and hard factory resets, different SIM card.
Also tried updating via the mobile app but no dice, doesn't detect the new version.
And stupidly it appears Netgear don't make the latest firmware available on their website so I haven't been able to update the unit manually.
I'd rather not go through the hassle of returning the unit so anybody here know where the new firmware can be downloaded from?
TIA
- BeAuMaNApr 04, 2018Tutor
There is no firmware download or manual update option available. The M1 can only download firmware automatically, or via the update firmware option in the firemware menu, which then downloads automatically from your Service Provider. This is something that's been griped about for a while, since a router is not a consumer-simple-device like a cell phone, and therefore we should have the option to download firmware updates ourselves and get firmware patch notes. But this is not the arrangement (Assuming Telestra has the same warranty agreement as AT&T, only they can handle warranty issues, not Netgear).
