arturoe
Jun 01, 2017Aspirant
where can i buy netgear lb2120 for EU
im trying to buy lte wifi modem netgear lb2120 in EU for spain. I can't find it in amazon.es (and any of the other links the page gives as sellers) and it is important to buy it as the lte bands are...
arturoe
Jun 27, 2017Aspirant
hi, Is there any info about when will it be available in Spain?
By the way in the spanish version the model 2120 (US) is listed as available as it is already available in spain but i guess the LTE is not compatible with spanish frecuencies. It would be good to have the link to pre-order instead purchase as it can lead to some confusion.
BartZorn
Jul 04, 2017Aspirant
I have the same problem. It is exceedingly difficult to get some real answers through the Netgear web site.
The spanish web site does suggest that the LB2120 is available, but none of the suggested vendors know about it.
I do know that there exists a LB2120-EUS something, as does a LB2120-NAS something. This suggests an European and a North American version.
Netgear would do well to clear up some of this mess!
Bart
- BartZornJul 04, 2017Aspirant
Additional problem is that the Netgear LB2120 seems to be the only 4G LTE modem with the ability to operate in bridge mode.
I have done an extended search but no other vendor seems to have a modem with this capability.
So we are stuck with Netgear, but they cause a lot of trouble to potential buyers.
Sad.
Bart
- BartZornJul 06, 2017Aspirant
I found two LB2120's on Ebay, one from Germany and one from Italy.
Both state that the official vendor type number is LB2120-100EUS. This suggest that it is indeed an European version.
Unfortunately, both are rather expensive.
Links:
Bart
