KaiKropp
Aug 03, 2020Aspirant
Where can I Download the Latest Firmware for MR1100 EUS
In urgently need to re-flash my firmware after an OTA update to NTG9X50C_12.06.12.00! Due to the USB Flash Drive Mounting Bug my Router stoped to operate once again. (So still not fixed on the la...
erichsch
Aug 05, 2020Star
Look at this link: https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/MR1100EUS-Firmware-V12-06-12-00-please-put-it-in-your/td-p/1943636
Netgear is not able to put the last Firmware in their Downloadcenter.
I dont know why?!
- KaiKroppAug 05, 2020Aspirant
**bleep** support and even more **bleep** product! 300€ and a year of work and never worked reliable for more then a few hours!
as soon as i resurected it (some day they will relese this firmware!) i´ll sell it like a hot potato.
Allready build an old FritzBox with a LTE stick in my RV to replace this....
Most epic fail of hardware i had in years!
- erichschAug 05, 2020Star
the newest firmware is not so bad.
but i cannot install it over OTA. there is a problem in my router. i can make updates only direct with a download.
but the last Firmware will not find the way into the downloadcenter.
so i have asked Netgear to put it in their downloadcenter.
my first question for newest Firmware to NETGEAR was two month ago.
NO SOLUTION FROM NETGEAR! BAD SUPPORT!
It still has the cathastropic bug that once you use a external drive with it and the router shut´s down or enters standby on it´s own you have a 1 to 5 chance it never ever will provide WiFi nor LTE Connection again.
Only way out is you re-flash and re-setup the thing. I baought it a year ago, exchanged it two times and sriouesly did not use it for more then a hour without failure...
this happend again only a vew minutes after updating to the latest FW because the router did shut down on a "overheated battery" new bug more fun....
I bought it last year for a 5 week trip to scandinavia, it failed the first time a day befor we land to start. delayed my trip to wait for a replacement wich faild again 10 Minutes after i installed it.
went on the trip without a router (pain wiht two teenagers on board ).
when i returned i replaced the router a secound time, only to learn it failed again after the first aout standby! beeing a long year professional in electronics and IT i now was sure this is not a hardware bug at all and started inverstigating the problem togehter with netgear.
Solution, if it fails reflash and reinstall, shut of all auto standby! wich worked ( while unsatisfactory ) and has never revieced a real fix to day!
now the f**ed it up again a week befor i go on a 4 weeks trip!!! I´m done with it! 300€ wasted not speaking about the time invested in this.
And now i have a brick on the desk that i cannot even re-sell to compensate the loss...
