KaiKropp
Aug 03, 2020Aspirant
Where can I Download the Latest Firmware for MR1100 EUS
In urgently need to re-flash my firmware after an OTA update to NTG9X50C_12.06.12.00! Due to the USB Flash Drive Mounting Bug my Router stoped to operate once again. (So still not fixed on the la...
erichsch
Aug 05, 2020Star
Look at this link: https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/MR1100EUS-Firmware-V12-06-12-00-please-put-it-in-your/td-p/1943636
Netgear is not able to put the last Firmware in their Downloadcenter.
I dont know why?!
KaiKropp
Aug 05, 2020Aspirant
**bleep** support and even more **bleep** product! 300€ and a year of work and never worked reliable for more then a few hours!
as soon as i resurected it (some day they will relese this firmware!) i´ll sell it like a hot potato.
Allready build an old FritzBox with a LTE stick in my RV to replace this....
Most epic fail of hardware i had in years!
- erichschAug 05, 2020Star
the newest firmware is not so bad.
but i cannot install it over OTA. there is a problem in my router. i can make updates only direct with a download.
but the last Firmware will not find the way into the downloadcenter.
so i have asked Netgear to put it in their downloadcenter.
my first question for newest Firmware to NETGEAR was two month ago.
NO SOLUTION FROM NETGEAR! BAD SUPPORT!
- KaiKroppAug 05, 2020Aspirant
It still has the cathastropic bug that once you use a external drive with it and the router shut´s down or enters standby on it´s own you have a 1 to 5 chance it never ever will provide WiFi nor LTE Connection again.
Only way out is you re-flash and re-setup the thing. I baought it a year ago, exchanged it two times and sriouesly did not use it for more then a hour without failure...
this happend again only a vew minutes after updating to the latest FW because the router did shut down on a "overheated battery" new bug more fun....
I bought it last year for a 5 week trip to scandinavia, it failed the first time a day befor we land to start. delayed my trip to wait for a replacement wich faild again 10 Minutes after i installed it.
went on the trip without a router (pain wiht two teenagers on board ).
when i returned i replaced the router a secound time, only to learn it failed again after the first aout standby! beeing a long year professional in electronics and IT i now was sure this is not a hardware bug at all and started inverstigating the problem togehter with netgear.
Solution, if it fails reflash and reinstall, shut of all auto standby! wich worked ( while unsatisfactory ) and has never revieced a real fix to day!
now the f**ed it up again a week befor i go on a 4 weeks trip!!! I´m done with it! 300€ wasted not speaking about the time invested in this.
And now i have a brick on the desk that i cannot even re-sell to compensate the loss...
... and no help from NETGEAR. :-(
You must remember this when you will buy a new Router.
I will remember the "famous" support from NETGEAR!
All Network components in my home are from NETGEAR.
WIFI 6 and Mesh is coming and i change to ASUS.
