RLBJR
Dec 20, 2024Follower
Where can I get a book on the M6 Pro Mobile Router. Model Number MR6500
Where can I get an instruction manual for MR6500, M6 Pro mobile router. It will not connect to my iPhone so I do not have a hotspot that I can use for my iPhone. It keeps saying no connectivity. ...
Dec 20, 2024Guru - Experienced User
https://www.downloads.netgear.com/files/GDC/MR6500/MR6500_MR6110_UM_EN.pdf
You might check with the ISP if there's any specific settings/apn setup that is needed for connectivity.
