electricpurple
Jun 11, 2021Aspirant
Where is Guest network setup on an MR1100
The interface on my Nighthawk MR1100 does not have a guest setup option in the Settings dropdown like I see on youtube. Is there a frimware update that adds this or is there some other trick?
electricpurple
Jun 13, 2021Aspirant
Yes, mine is the MR1100-100NAS. if it is only the ATT version with a guest network then I will be returning mine to Amazon and going with a more robust Pepwave product. Thanks for yor assistance!!
michaelkenward
Jun 14, 2021Guru - Experienced User
The manual says nothing about AT&T only.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Select a WiFi Profile.
