WDT74
Apr 10, 2020Follower
Which APN details do I input
Dear Community,
I'm unsure which details to place in the APN field window under the settings via the mobile app. the following are required:
APN name:
APN:
Authenication:
I am using a Vodafone sim, have followed their video tutorial on APN details and collected data.
Question: What is the correct information to be entered?
I look forward to your advice, thank you.
Kind regards Wayne Taylor.
1 Reply
- JohnPengNETGEAR Expert
Are you using MR1100-100EUS device? Which country are you in? Do you have the Vodafone APN info?
Thanks
