Swannbm's avatar
Swannbm
Follower
Nov 12, 2020
Which connector for M2 Nighthawk Antenna
Hello,
I have bought antennas for my routeur M2 but I can't find the correct plug. I've bought CRC9 and TS9 but neither seems to be correct. Can you tell me which type of connector is correct ?
May be the antennas are not compliante with world wide standard.
Can you tell me which antennas are recommended ?
Thx a lot.
No RepliesBe the first to reply
