bonne
Feb 01, 2022Aspirant
Which LTE/5g modems/routers supports flawless bridge mode/passthrough
I live in a location with no decent cabled internet, so I am looking at a 4g/5g solution as this should give me a decent speed over my cabled alternatives But I need an unfiltered, 100% bridge/passt...
- Mar 06, 2022
Thanks - I actually ended up buying a Zyxel where the feature actually was clearly documented - and it actually works (-;
Regards, Lars.
Feb 01, 2022Guru - Experienced User
Netgear has set up a community forum specifically for the Mobile Router products. Most of the people who watch that forum are more likely to have experience with mobile routers. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
Thank you
