bonne
Feb 01, 2022Aspirant
Which LTE/5g modems/routers supports flawless bridge mode/passthrough
I live in a location with no decent cabled internet, so I am looking at a 4g/5g solution as this should give me a decent speed over my cabled alternatives But I need an unfiltered, 100% bridge/passt...
- Mar 06, 2022
Thanks - I actually ended up buying a Zyxel where the feature actually was clearly documented - and it actually works (-;
Regards, Lars.
qz123
Mar 06, 2022Tutor
Hi, my ZTE MU5001U(also Qualcomm x55, but no battery, no screen, and powered by typec, another model ZTE MU5001 have a screen and battery) have this bridge feature, and I am using it at my house. I am not sure it is you want, so i can just put a screenshot about it.
My MR5200 only use for outside, becuase it have a battery.
Screenshot:
https://zzstatic.oss-cn-hongkong.aliyuncs.com/Snipaste_2022-03-06_12-12-54.jpg
- bonneMar 06, 2022Aspirant
Regards, Lars.
- samantha_jtJun 22, 2022Aspirant
Hi, how did you get the MU5001 into bridge mode?
