Schutti
Jun 27, 2018Apprentice
Which TDD Settings are supportet? TDD/FDD CA? TDD 4x4 MIMO?
I have a M1 Nighthawk MR1100 EUS
In the data sheet the Bands 1,3 and 7 are listet for 4x4 MIMO support.
The 2600 TDD Band (Band 38) can use 4x4 MIMO?
My provider is use Band 38 ...
plus-sk
Jun 28, 2018Apprentice
No, with TDD Bands you can't use 4x4 MIMO mode. With MR1100-100EUS you can use 4x4 MIMO mode with LTE FDD Bands 1, 3 and 7, includiung some FDD-only 3CA combinations with these bands.
Schutti wrote:
Which settings /Upload/Download are supportet, can the M1 use QAM256/QAM64 on TDD too?
Yes, 256QAM is working even with TDD bands (for downlink). It's a modem chipset function.
Schutti wrote:
Carrier Agregation support between TDD and FDD Bands?
MR1100-100EUS should work with such FDD + TDD combinations:
- CA_3_40;
- CA_3_41;
- CA_1_3_41.
Schutti
One more question:
In the PDF: 4x4 MIMO for Band 1,3 and 7.
Band 7 (FDD) and Band 38 (TDD) are both 2600 MHz.
Can 4x4 MIMO be used by the M1 on Band 38?
