rabbieb
Mar 19, 2018Guide
Why Has 5 GHz WiFi stopped after firmware update
I updated my M1 Nighthawk firmware to NTG9X50C_10.25.01.00 and now I've gotno 5.0 GHz connection. Settings / Setup / Wifi Profiles shows that 2.4 & 5.0 are still enabled as before but I cannot conne...
rabbieb
Mar 24, 2018Guide
Hi Jason
Latest situation - did a factory reset - that did not roll back the firmware - still have multiple wifi connectivity issues - decided to try and reinstall the firmware - cannot do that - Netgear's download site says no firmware available for this model - cannot reinstall from the device because it says firmware is uptodate - cannot do roll back either - Telstra says it does not provide device support it is Netgear's problem. So I'm stuck.
JasonN
Mar 27, 2018NETGEAR Employee Retired
Hi rabbieb,
I know you are on the other thread as well. In the other post I said I will forward this to my internal team and have them look into it. I will update everyone when I receive more information. :]
- Jason N
