CTS-59
Aug 23, 2020Tutor
WiFi disabled on Nighthawk M2
Hi I have just set up my Nighthawk M2 out of the box, and all seemed fine - connection to my EE providor is fine. Then the WiFi shows a red cross, and is disabled. I have tried rebooting, and also rev...
CTS-59
Aug 25, 2020Tutor
Hi W1lliam
Thanks. The charger I've been using is the one supplied in the box - sorry, I'm in the office, and this is at home.
Previous factory resets have been with the battery installed and with the pin, via the unit interface, and via the web interface. I gave it a further go just now, but this time without the battery - power is via the USB from my laptop. selected 5Ghz only, and never sleep wifi.
Still no change, unfortunately.
