Aya1009
Dec 29, 2017Follower
Wifi doesn't work
Dear all, I've got a problem with my wifi router, here are the situations and need advice for troubleshooting. ・Its model is DG834G ・Internet provider is talktalk and the router also conne...
mdgm-ntgr
Dec 30, 2017NETGEAR Employee Retired
Have you checked the ADSL filters are working properly? This sounds like a filter either isn't installed or isn't working properly.
