AlexinQLD
Jan 10, 2024Aspirant
WIFI extension options for Nighthawk M2 router.
We live in rural Queensland and use a Netgear Nighthawk M2 router for WIFI access We get poor cover coverage across the house and we would like to improve this? We are considering two option...
Jan 11, 2024Guru - Experienced User
I'd would get a router or mesh system and connect to it.
The reason why is the why on hotspots/cell spots is limiting in how far the wifi can broadcast. Its part of its broadcast regulation since they're designed to travel.
If you get a router/mesh system, it doesn't have that restriction. Plus they tend to have more cpu/processing power and be more capable.
AlexinQLD
Jan 14, 2024Aspirant
Who you suggest buying either a Orbi or Google nest system?
