mhonenscene's avatar
mhonenscene
Follower
Sep 13, 2019
WIFI IS NOT WORKING ON MY NIGHTHAWK M2 ROUTER
HOW TO FIX THE WIFI CONNECTION ON MY NIGHTHAWK M2 MR2100 ROUTER IS SHOWS X ON THE SCREEN I CAN'T CONNECT THROUGH WIFI ON THE ROUTER
  • plemans's avatar
    to start off with. You're in the wrong forum. The mobile routers section will have better help and people more knowledgeable about this issue.
    https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
    2nd, please hit the caps lock key to the left of the "A"
    3. What screen has an x on it?
    4. What have you tried to do to fix the problem? reboot, reset, etc.
    5. here's your support page with manuals, troubleshooting, downloads, etc.  These can be very beneficial.
    https://www.netgear.com/support/product/MR2100.aspx
    • mhonen's avatar
      mhonen
      my netgear nighthawk m2 router wifi is not broadcast or not functioning..as showing on the attach file..
      • plemans's avatar
        I put a link to the manual in my first post. It has a bunch of ways to access and manage the device.
        1. have you tried connecting it via usb to a computer and managing it?
        2. Have you tried connecting via the ethernet port and logging into manage it?
        Starting on page 20 of the manual it goes over tethered connection, ethernet connection, and logging in to the management software where you can turn features on/off from the interface.
        have you tried either of these? Or did you try resetting the device back to factory?
