kelvinkendkk
Apr 22, 2025Follower
Wifi offloading fail on M6 MR6110
Model: MR6110
Firmware: NTGX65_12.01.54.00
OS: MacOS
I am using the latest firmware on my Netgear M6 MR6110. But I would like to connect wifi using offload to reduce my data usage.
It seems like cannot show my wifi list even I entry manually on phone app to assign the Wifi SSID and password to it but still fail to connect automatically.
- RB1VIPAspirant
Sorry, hopefully these pictures are better quality!
- RB1VIPAspirant
Model: MR6110
Firmware: NTGX65_12.01.48.00
Firmware Build Date: 2023/11/07
Hello there, I have exactly the same issue. My MR6110 is unlocked and I use it with an o2 unlimited internet sim-card which works fine. All features work, other than WIFI offloading. No WIFI networks are shown? The only difference I can see, is my firmware is different, yet every attempt I've made to update the firmware, a message saying the firmware is up to date is displayed.
Following other some trouble shooting guides a recommendation to change the IP subnet address, which didn't work. Logically there can't be a conflict with my home network as the M6 doesn't see any WIFI networks and there are plenty in the area.
