Marshtours
Feb 07, 2019Follower
wifi router for tour buses
Whats the best option for wifi connection on a tour bus
Oxygene
Feb 09, 2019Apprentice
Simple battery operated mifi should be fine at the begining. How many seats is there? Some operates up to 32 connections and some much less up to 10. So keep that in mind...
- JSchnee21Feb 10, 2019Virtuoso
Without a doubt. Cradlepoint.
https://cradlepoint.com/content/cor-routers
But it's not cheap -- $1000-1500. Plus the cost of data -- which will be very expensive.
- MobileWiFiGuyFeb 10, 2019TutorCradlepoint routers are very low-grade devices. I've seen numerous major bus operators try them and eliminate them out of frustration.
- MobileWiFiGuyFeb 10, 2019TutorMiFi routers are NOT suitable for buses. That is terrible advice.
