emtr3
Jul 07, 2018Tutor
WiFi slow on MR1100
Why is the wifi slower on the US version of the Nighthawk M1 then it is in the Australian version on Telstra? People are getting real world speeds of 200+mbps over WIFI? Whereas I can only get max no ...
- Jul 10, 2018
Hi emtr3,
I'd say trying taking it to an AT&T store and see if they will swap it out for you.
-Jonathan
JSchnee21
Jul 07, 2018Virtuoso
Hi emtr3,
Help me understand. Do you have the US version, and your friend has the Australian version? When you are both here in the USA, he gets 200Mbit and you get 30Mbit? Are you sure you are both on AT&T? Is he roaming onto a different carrier -- like Tmobile or Verizon?
I routinely get ~20-60Mbit on AT&T in PA and NJ -- across all of my AT&T equipment (iPhone 6s, iPhone 5s, MR1100, Velocity 2). Best case, when very near (1000 feet) a strong AT&T cell tower with fiber backhaul I might get 90-120Mbit. Best speeds I've ever seen on AT&T were ~150-160Mbit. This was on my 6s, on the MR1100 I've only ever gotten 120Mbit.
I suspect that AT&T is being very stingy with carrier aggregation. Also, they don't have 20MHz chunks on most carrier bands. Often just 5 or 10MHz. It could be that the AUS version is more aggressive at aggregating across multiple carrier bands. AT&T may be limiting this.
AT&T seems very slow in implemeting 3x and 4x CA, along with 256 QAM, and 4x4MIMO. Tmo and Verizon are way ahead in this regard.
-Jonathan
emtr3
Jul 07, 2018Tutor
The MR1100 not the 1100-eur or -aus. My m1 is through att and by counterparts I just mean other mobile modems that you see in videos on YouTube, one video is someone sitting in what seems to be a small café and seamlessly pushing well over 200mbps. It's quite interesting that I am only finding those speeds on the aus versions of the modem. It's a more than capable modem I can tell you that. Cat 16 modem in it too which is impressive but I feel att is either slowing it down or their firmware is impeding its performance. Kinda curious to see how an unlocked eur or aus modem would perform on att. In my town theres a few spots where 180mbps is average.
- JSchnee21Jul 08, 2018Virtuoso
Hi emtr3,
Like I said, my MR1100 is the also the US version on AT&T. I have seen speeds up to 90-120Mbit from the MR1100 over Wifi (5.8Ghz,802.11ac,40Mhz, 2x2). BUT, these speeds from AT&T are rare where I live.
In general the MR1100 gets the exact same speeds as my 6s for a given cell toiwer distance. Sometimes the MR1100 is a little faster, often my iPhone is a little faster. My Velocity 2 is usually right there, but slightly slower.
AT&T does play games with which bands certain devices are configured to prefer. Previous versions of MR1100 firmware seems to have some "band hopping" issues where the device was often switching from band to band too frequently. Current firmware seems better.
Which hardware version of the MR1100 do you have? Wat AT&T model number? There supposedly was a Gen2 released after April 2018 which has Band 14. Supposedly get Gen1 version like I have does not. None have LAA yet. Of course AT&T's rollout of Band 14 is pretty limited.
I'd suggest benchmarking your phone over LTE side by side with the MR1100 in multiple locations / towers / times of day. After doing this on numerous days along my drive to and from work (124 miles round trip), I've convinced myself that they are the same, and that AT&T's network or baseband provisioning config is the limiting factor -- not the device. The MR1100 seems to do pretty well with very little signal. Often pulling down 15-30Mbit with signals less than -100 dBA.
Many would agree the fastest possible LTE device you get get today (with the best reception) is probably one of the Samsung Galaxy devices like the S9. On Howardforums these seem to post the fastest speeds across multiple carriers (AT&T, Tmo, and Verizon). The S9 even supports LAA -- which isn't really Cellular at all, just gloried wide area Wifi.
-Jonathan
- emtr3Jul 08, 2018TutorI have the mr1100 i'm guessing the second iteration with band 14 support, I have the 6420B model. Firmware is 12.02.06.01 and is current fota fw. I'm unclear of its support on the 14 band but the problems not signal its just the wifi, I guess I'll just have to wonder to the area where I get 4CA on my s9+ to find out. I know i get manic speeds there but havent tried in a while with the m1 modem since the last time I tried it, it was still 30/30mbps last time I tried wondering about the hot zones with 2CA &3CA towers. The speeds on this new cat 16 modem with the s9+ are quite consistent. But I fear now I might have a faulty radio or just too much 5Ghz interference, I've accounted for the crowded 2.4g by disabling it but even then only a 10mbps (40/30) max before it settles down to 30/30 or sometimes 20/30 which doesnt make sense considering that uploads usually 5-15x lower than downlink.... in the common area I use it over ethernet I get on average 80-105mbps, but cannot exceed more than 40mbps for like 2seconds also on many devices, GS9+, GS8, note 4, and a simple little 2.4g tablet.
- emtr3Jul 08, 2018TutorMaybe it's a broken uplink antenna or faulty device. As you can see it's got quite the upload definately enough to support download speeds of up to around 300mbps theoretically but it's just not pushing me the speed I want.
