gokulbro
Apr 01, 2020Follower
wifi turned off in log in
i turned off wifi in my router login page accidently on my MR1100, now it shows wifi disconnected. how to turn it on,because i cannot login to netgear login page cause it demands the same network fr...
Blanca_O
Apr 07, 2020NETGEAR Employee Retired
Hi gokulbro
Welcome to NETGEAR Community!
You can wired a computer to MR1100 for you to access the settings page. Once logged in, go to Settings > Setup > Wireless.
Another option is to factory reset MR1100.
Blanca
Community Team
aloisegam
Jul 07, 2020Aspirant
I had a similar problem with my travel router . I think I had accidentally turned off the Wi-Fi connection. It gave me so much stress on the road since I was supposed to work and send reports periodically. This little hack really helped me and I was able to login and get internet access on my M1 mobile router. I just accessed the settings then clicked on the setup and changed it to wireless. I could not afford to reset the factory settings since I did not have the time and energy to start all over again.
I recommend the best Netgear routers every time since the customer service is great and these forums have solutions for most of our challenges. Some of these simple hacks can be very stressing incase you don't know about them.
