kabir14's avatar
kabir14
Follower
Apr 26, 2023
Will a AT&T Netgear AirCard 815S or Netgear Nighthawk MR1100 LTE mobile hotspot work on Verizon?
AT&T service is unreliable in my area. Sometimes it's fine, other times I can't even ping google. I'm going to get an unlimited backup mobile hotspot plan through Visible or Nomad Internet. Visible is most attractive because it's as low as $25/month for unlimited data. Visible runs on Verizon... but I have both an AT&T AirCard 815S and an AT&T Netgear Nighthawk LTE hotpot. It would be great if I could use one of these, but I can't find any definitive info on running either of them on Verizon. Does anyone have any advice or experience here?
1 Reply
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    Both AC815 and MR1100 are not Verizon certified. That means you can't activate a brand new SIM from Verizon network with these devices. But if you can activate a Verizon or Visible SIM card on a certified device, you can use the SIM card on AC815S and MR1100. You need to adjust your APN setting accordingly. This may be challenging sometimes.
    Thanks
    John
