tjkcc
Dec 15, 2015Aspirant
Will AC785 hotspot work in the US?
Hi, I'm planning to purchase AirCard 785 Hotspot (http://support.netgear.com/product/AirCard%2B785%2BRetail%2Bunlocked) and wondering if it will work when I travel to the United States.
DarrenM
Dec 16, 2015Sr. NETGEAR Moderator
Hello tjkcc
yes this will work just need a micro sim from a US carrier to use it or check with your current carrier if they have a international plan that works in the US.
DarrenM
Noumka
Jan 02, 2016Aspirant
we are going to japan in the futur next month and will buy this 3g 4g wifi hotspot to shere a sim card data that we may buy outa there in japan but still this question remains...
Will the Netgear AC785
link below
http://www.netgear.fr/home/products/mobile-broadband/hotspots/AC785.aspx#tab-spécifications
be working on the japanees network sys and
with a japanees sim card
thanks for your futur help :D
- DarrenMJan 05, 2016Sr. NETGEAR Moderator
Hello Noumka
If the Sim card you get for the AC785 is one of these bands it should work.
2G 900/1800 MHz
DarrenM
- Dual Band Wifi 802.11n avec 2 SSIDs simultanés
- LTE cat 4/HSPA+/EDGE/GSM
- 4G LTE FDD 800/850/900/1800/2100/2600 MHz
- 4G LTE TDD 2600 MHz
- 3G 850/900/2100 MHz
