DDay2017
Jun 07, 2017Aspirant
Will LB1120 work with Verizon LTE?
Will this modem work with Verizon LTE network? I am in a remote area with only SLOW dsl from land-line provider. Would like to use LTE as my only WAN access..any thoughts? TIA , David
- Jun 08, 2017
It will work wth Verizon LTE, however when you try to activate a SIM card there may be some issues as the IMEI or model is still not in their database. I used a SIM card already registered to a Cell phone and it works fine.
PJBeee
Jun 18, 2017Aspirant
Sorry...To be clear, I had the very same experience as Nobbley.
- DDay2017Jun 18, 2017Aspirant
Thanks for your input. So is it safe to assume that as long as the SIM device type can be found in the VZ database, it should work... Yes?
- PJBeeeJun 18, 2017Aspirant
Far as I can tell, as long as you have a valid Verizon micro-SIM, registered to any LTE-capable device acceptable to Verizon, you can then transplant that SIM into your LB1120, apparently without issue. The problem, of course, is that you need this workaround as long as the LB1120 IMEIs are not in Verizon's database.
A NANO-SIM in MICRO-SIM adapter should also work.
And you may not be able to register that original device again with Verizon, now that its registered SIM is in your LB1120.
