Qountdown's avatar
Qountdown
Will M6 pro model MR6500 (unlocked) work in Europe?
Hi,
Can't seem to find a definitive answer.
Would the above ''M6 pro model MR6500 (unlocked)'' work in Europe?
It is not carrier branded by a mobile network, if that would make a difference.
Thanks
  • This might be unrelated, but I’ve used my MR6500 from AT&T USA with international day pass in Barcelona and it’s connected to Orange 4G LTE and Vodafone 5G. The speeds were 35 Mbps down/20 Mbps up and 85 Mbps down/10 Mbps up respectively. Although I’m sure speeds will vary based on where you are.
  • Just out of curiosity, what do you mean by "unbranded"?  I thought that all MR6500's were ATT branded.  It might make a difference.
