UNREALSKILL's avatar
UNREALSKILL
Will MR6110-111AUS work in indonesia 5G Bands?
Hello,
I have question about Netgear Nighthawk M6 MR6110-111AUS.
I see if it's have same frequency in indonesia Product Data Sheet MR6110-111AUS
5G Bands1, 3, 5, 7, 8, 28, 40, 41, 78
I'm planning to buy this model because in Indonesia 5G Bands Frequency is N1, N3 & N40.
Will it work on indonesia?
  • UNREALSKILL wrote:
    Hello,
    Get this instead: MR6150-100EUS. It is an unlocked device, and has the 3 bands you need. The MR6110-111AUS is a locked device from what it looks like on the spec sheet.
    • UNREALSKILL's avatar
      UNREALSKILL
      I got it,
      On the Product Data Sheet
      it say supported for network 5G Bands N1, N3 & N40.
      i will gacha buy this from the seller who say if it's unlocked and it comes with original packaged.
      But, if it's locked can i unlock it using D* Unlocker?
      • rcpax's avatar
        rcpax
        Luminary
        I don't know any legitimate method to unlock it, therefore I can not answer your question. If you have somebody trying to sell you an unlocked version, you will be buying it at your own risk. The router model you are interested in were released for certain operators and they come from the factory as locked devices.
