CBCrosby8155
Mar 03, 2021Aspirant
Win 10 desktop will not connect to MR5100
My Dell (Windows 10) desktop will not connect to my new MR5100. I contacted Dell and they say I need a an updated wifi card. Current card (Intel AC7260) is not compatible. Looking for suggestions ...
Mar 03, 2021Guru - Experienced User
the intel 7260 will work fine with AX. You just need to update the driver directly from intel and not through dell.
CBCrosby8155
Thanks. The drivers have been updated and still no connections.
- plemansMar 03, 2021Guru - Experienced User
What driver version do you have installed on the computer?
I have an intel 7260 and its connected to my RAX200, CAX80, and an WAX218 without issues
- CBCrosby8155Mar 03, 2021Aspirant
I am not sure but Intel said I have the latest.
All my other devices connect to the MR5100 without problems, including a Dell laptop, HP printer, Mac mini, etc.
I am currently connected to a Verizon jetpack so I at least have internet service.
The desktop has always connected to any internet providers I have used in the past.
If you go to your device manager, then click on the intel 7260, you should be able to find what driver version you have there.
