TechEnder_9
Mar 14, 2018Aspirant
Wireless AC adaptter
in the morning everything was fine, everything was running smoothly but when i got back from work later that night my ac adapter wouldn't pick up on the internet, my other devices were connected to th...
UK-based
Mar 14, 2018Luminary
You probably need to give a bit more information to enable people to help you:
Make and model of router?
Make and type of AC adapter?
- TechEnder_9Mar 14, 2018Aspirant
my router isnt special i have it through midco, my adapter is AC600 Dual Band model No.A6100. as additional info i installed the same software and tried the same hardware on my laptop and it works but when i plug it in my pc it will connect to the router but wont receive the internet
- UK-basedMar 14, 2018Luminary
I'd ask this question in the WiFi Adapters section, which covers the Netgear AC600 (Model A6100). You're more likely to get an answer there.
