philhil
Dec 11, 2023Follower
WLAN router with detachable antennas
Hello everyone, I am looking for a WLAN router to connect mixing consoles and other things at events. To get a long range, I would like to connect an external antenna (two pieces) via RP-SMA con...
Dec 11, 2023Guru - Experienced User
here's the problem. You add a bigger antenna that focus the connection. But it narrows where it focuses it. So if you have multiple area's to cover, it doesn't help. There's a much longer description here:
https://dongknows.com/wi-fi-dbi-and-high-gain-antennas-explained/
You might be better off switching to a mesh system versus trying to add bigger antennas
JohnPeng
Dec 11, 2023NETGEAR Expert
Thanks for the above link. It is really good to read.
