LC78's avatar
LC78
WNCE 2001 problems
Any help would be appreciated,    I have a WNCE2001 and according to documents if the red on the power light stays on, power source is low. However I replace the Transformer with a new one and the ...
  • plemans's avatar
    Jul 22, 2020
    It might be time to call it. It could be a hardware failure that's manifesting as the red light.
    If you're replaced the power supply and tried resetting it, it might be time to stop investing time/money in getting it working.
    Its a 10 year old device that is pretty base level.
