LC78
Jul 22, 2020Aspirant
WNCE 2001 problems
Any help would be appreciated, I have a WNCE2001 and according to documents if the red on the power light stays on, power source is low. However I replace the Transformer with a new one and the ...
- Jul 22, 2020
It might be time to call it. It could be a hardware failure that's manifesting as the red light.
If you're replaced the power supply and tried resetting it, it might be time to stop investing time/money in getting it working.
Its a 10 year old device that is pretty base level.
LC78
Thank you,
By any chance anyone happens to know of a similar device with similar dimentions that will work with a Netgear N600 router? I'm looking for compability and reliable.
Jul 23, 2020Guru - Experienced User
Many of netgears extenders have an ethernet out port. You could go for something like the EX3700 which is a n600 device. I believe you can even set it up in fastlane so it sets the 5ghz or the 2.4ghz as the dedicated backhaul
