Jrod82366328
Feb 20, 2021Follower
Won't connect to cellular dat
Sorry if this is dumb but my nighthawk m1 tells me to turn on cellular data and to go to setting then to network to turn it on. The problem is there is no option to turn on cellular data in the setti...
michaelkenward
Feb 21, 2021Guru - Experienced User
Is that something that you have to do with the cellular operator?
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
Look for the model number on the label on the device. (Probably MR1100.)
Check the section in the manual Specify Cellular Settings.
You may have done this already. I can't tell from your message.
