Pender
Jun 19, 2022Follower
Yellow triangle
M1MR1100. Yellow triangle on display screen. Unable to remove it. Any help would be appreciated.
1 Reply
Pender wrote:
M1MR1100.
What's that? The MR1100 mobile router?
What screen? On the device itself? Somewhere else?
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems
Those things are very different from the standard Netgear routers covered in this section.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
