bkenobi
Oct 28, 2019Aspirant
Yet another MR1100 antenna configuration question
I've have an MR1100 connected to AT&T for a little over 1 month. I am replacing a rediculously slow DSL setup (1/0.3mbps d/u) for my home internet with this and during testing find that I can get up ...
LTEGuy
Oct 28, 2019Star
Hi, a couple of suggestions to your problem:
I think RG6 is 75 ohm cable and M1 system is 50 ohm. Try using a 50 ohm coaxial cable, RG58 is a good choice. If you prefer the Wilson brand, Wilson 400 is a good cable as well. Also, keep the cable as short as possible.
hope this helps.
bkenobi
Oct 29, 2019Aspirant
I didn't realize that the M1 was 50ohm. I specifically bought the 75ohm version of the Wilson antenna because I thought RG6 would be a good quality cable without all that much loss. Although LM400 would be a great option for signal, I have a constraint that it must fit through a conduit to the attic that already has a lot of other runs. I know I can fit 2 and hopefully 2 RG6 easily, but even 1 LM400 cable would be a very difficult task.
I spoke to Wilson Electronics today and they recommended looking into RG11 cable. In looking at it online, it appears to be a pretty big jump in size (not like 400 of course). RG58 appears smaller than RG6 and is 50 ohm. I can go that route if it will work with the Yagi's I have, but I'm wondering if I'd be better off trying a different antenna in 50 ohm if I go with 50 ohm cable.
- bkenobiNov 01, 2019AspirantOut of desperation as a last ditch effort before packing everything up for return, I tried buying new F to TS9 adapters. One of the original ones fell apart at one point so I figured maybe they are both junk.
After testing many configurations last night, I have found 0, 1, or 2 antennas with 5', 50', and 75' of RG6 all work equally well to provide 20Mbps+ download rates to my laptop. With my phone, I can get up to 45+ which is what I achieve with my phone to tower directly, so the laptop (2012 model) is holding speeds back and not the hot spot.
Any recommendation on keeping the TS9 plugged in without damaging anything? The connector seems REALLY fragile. In fact, I bought 4 and the first one snapped a corner of the male plug on the adapter. Seems like a bad design.- Joyce955Nov 12, 2019Aspirant
Any recommendation on keeping the TS9 plugged in without damaging anything? The connector seems REALLY fragile. In fact, I bought 4 and the first one snapped a corner of the male plug on the adapter. Seems like a bad design.I specifically bought the 75ohm version of the Wilson antenna because I thought RG6 would be a good quality cable without all that much loss. Although LM400 would be a great option for signal, I have a constraint that it must fit through a conduit to the attic that already has a lot of other runs. I know I can fit 2 and hopefully 2 RG6 easily, but even 1 LM400 cable would be a very difficult task.
