EDV01
Mar 12, 2024Aspirant
CLI problem with M4300
Hello,
i have a problems with the cli of M4300-52G switches after the input of passwods.
Sometimes the cli does not switch back from showing '****' after the input of secrets (enable...).
If this happens i can only kill the terminal session. I tried "exit", "quit", "^C", "^D" etc. pp.
I can see that i press the keys but nothing happens other than showing '*****'. It lets me not leave this modus.
When i try to configure a radius server and want to put in the key for this switch
'radius server key auth 10.20.30.40'
this happens every time! So i can not configure radius on this switches on cli.
I run the newest firmware 12.0.17.16
Normally i use OpenSSH on Linux, but i tried putty/Windows and even ssh/telnet from other Netgear-Switches to the cli of these M4300-52G to test this behavior. Its all the same.
Does anyone know a solution for this other than "Use the WebGUI"?
Some kind of terminal config wisdom?
regards
EDV
No RepliesBe the first to reply
