mgaudette
Mar 24, 2018Aspirant
How to limit port speed on M5300 switch
Hi, I have a pair of M5300 switches (stacked), and on one of its ports I have a device that sometimes saturates our 100Mbit/s uplink. Its traffic is legitimate (remote backups) but it impacts eve...
Retired_Member
Mar 26, 2018Hi mgaudette,
Welcome to the community!
If you want limit the uplink speed based on port on switch M5300. I suggest DiffServ function is available for you.
Below is the config step:
1. Class - Create classes and define class criteria.
Example: Class name is test, and match every;
2. Policy - Create policies, associate classes with policies, and define policy statements.
Example: Policy name is p1, Policy type is in, Member class is test;
3. Service - Add a policy to an inbound interface.
Example: port 1/0/1, select Policy in name to p1, then click apply button;
For detailed configuration about DiffServ, please refer to Link (page 524)
Hope it helps!
EricZ
NETGEAR employee
mgaudette
Mar 27, 2018Aspirant
Thank you - will try this
