larsks
Feb 26, 2020Initiate
m4100 d12g: Making sflow configuration persistent?
I'd like to persistently enable sflow on some ProSafe m4100 d12g switches. After following How do I configure statistical packet-based sampling of packet flows with sFlow using CLI commands on my managed switch?, running ...
show running-config | include sflow
...does not show any of the sflow settings, and after a switch reset, the sflow configuration is gone.
What's the correct way to make this configuration persistent?
1 Reply
- msiLuminary
I don't use sFlow, but concerning 'show running-config' it can be expanded by 'show running-config all' this shows also all options that are set to their default. If an option is left unchanged it won't be shown with the shorter command. :-)
Might it be that you forgot to 'write memory' or 'copy system:running-config nvram:startup-config' before rebooting the switch?
