g_williams's avatar
g_williams
M4300 - Static Multicast Join
Do any of the managed switch range (I've been looking at M4300) support statically joining a port to a multicast group?  Also referred to on other Netgear switches / previous firmware versions as "Configure Multicast Group Membership"
We have a scenario where a camera that needs to receive multicast PTP is not doing an IGMP Join.  Flooding unknown multicast is not really an option as the camera is also transmitting a multicast stream - which we would not want flooded to all ports.
Thanks,
Glyn
1 Reply
  • LaurentMa's avatar
    LaurentMa
    NETGEAR Expert
    Hi g_williams ,
    Welcome to the Community. I am sorry, there is no static multicast join in our Managed Switches. Instead, we have designed a very intelligent IGMP Plus that "unifies" all switches in the network without any flooding. When we need to "force" the multicast to a specific port, for instance when there is a server that needs to receive and record all mutlicast streams, we establish the mrouter mode on that interface. But I don't think this is what you need here.
    Let me tell you about PTP: your camera should receive the PTP Multicast, because these packets are going to a reserved Mutlicast address that is reaching all ports in a VLAN when IGMP Plus is configured. So your camera should receive it, while its own Mutlicast stream would operate with IGMP just normally.
    Please reach out to us at ProAVDesign@netgear.com if you need any more help, we will be happy to help design your AV network!
ProSupport for Business
