Nick_AIM
Mar 29, 2018Follower
M4300 sflow LAG support
Does this switch support sflow on the LAG's as we can't see the option, current firmware is 12.0.2.9? I've read the release notes for newer firmwares but none state this as a fix.
Thanks
1 Reply
- Anonymous
Hi Nick_AIM,
Welcome to the community!
Currently, the latest firmware is v12.0.2.20 for M4300 switch. Please click the link to download the firmware.Yes, the M4300 switch support sflow on LAG port, but only for a port of LAG member, below is the detailed information:
sFlow agent can export LAG counters for a port that is part of a LAG, along with Ethernet counters. The LAG counters exported to the sFlow receiver in the counter sample includes the following information:
- Actor and Partner ports system ID's.
- Actor and Partner ports admin and operational states.
- Statistics about different types of packets exchanged between actor and partner ports such as number of LACPDUs, Marker PDUs, Marker Response PDUs etc.,
This additional information (LAG counters) is exported in the sFlow counter sample only if sFlow is supported on LAG members. Note that sFlow configuration is only allowed on physical interfaces; i.e. not LAG interfaces.
Hope it helps!
EricZ
NETGEAR employee
