cadasp
Mar 27, 2018Aspirant
Migrating from xs712Tv2 to xs712t
I am Migrating from a xs712T to a xs712Tv2, is there any way possible to import the config file from the old swith to the new (import from XS712T to XS712Tv2? I'm hoping I will not have to configur...
LaurentMa
Mar 28, 2018NETGEAR Expert
Hi schumaku: XS712T Smart Managed Pro switch and XS712Tv2 newer version make part of same family, but different platforms. Configuration file structure will be slightly different, but it should be possible to "import" most of previous configuration:
- Download XS712T configuration file (Maintenance\Download\HTTP File Download\Text configuration) and open it in a text editor
- Download XS712Tv2 configuration file (probably the default one) and open it in a text editor
- Compare the structure of both configuration files: although similar, some differences may appear
- Try to import XS712T text commands into XS712Tv2 configuration, respecting the new structure, block by block
- When done, save a version of XS712Tv2 new configuration file on your hard drive and upload it in XS712Tv2 for test
Hi cadasp: Let us know how it goes!
cadasp
Mar 28, 2018Aspirant
thanks, I will give that a shot.
