akira168
Mar 20, 2017Aspirant
IP based ACL using GUI
Hi Netgear Community, Can someone give me an example to set up IP based ACL with GUI? What we want to do is just to permit all the services only from the network address, 192.168.55.0/24 on the ...
DaneA
Mar 29, 2017NETGEAR Employee Retired
I apologize for the late response. :(
Kindly try the steps below:
1. On the rule you have created, under Match Every, change "False into "True."
2. Create another rule: set the Action to Deny, set the Match Every to False and set both Destination IP Address and IP Mask to "Any."
Let me know if it helps.
Kindly read pages 748-749 of the M7100-24x user manual here and refer to the example Standard IP ACL configuration given as this might help.
DaneA
NETGEAR Community Team
akira168
Apr 04, 2017Aspirant
Hi DaneA,
Your suggestion is to block certain IP address and to pass the others, isn't it?
I am looking for the way to pass certain network address and to block all the others.
Besides I cannot block any IP address by using your instruction.
Thank you.
Best regards,
- DaneAApr 26, 2017NETGEAR Employee Retired
My bad. The Destination IP Mask should be a Wildcard Mask. Kindly try the steps below:
2. Then change the Destination IP Mask from 255.255.255.0 to 0.0.0.255.
3. Create another rule: set the Action to Deny, set the Match Every to False and set both Destination IP Address and IP Mask to "Any."
As reference guide, kindly read pages 748-749 of the M7100-24x user manual here and refer to the example Standard IP ACL configuration given.
Regards,DaneA
