_Karl_
Dec 16, 2021Aspirant
¿ VLAN Path between Cablemodem (Unitymedia Connect Box) and Router (Fritz! Box 7590) ?
Hello, we operate the Fritz! Box 7590 and the Vodafone cable modem (Unitymedia) Connect Box so that the Fritz! Box is located where our telephone connection was, so that ISDN can be made availab...
_Karl_
Dec 26, 2021Aspirant
As it is:
LAN
FritzBox as Router, that gets the IP4 assigned by the Internetprovider
Mediaconverter
Optical Fiber
Mediaconverter
Cablemodem
Internet
As it is shall grow
LAN__________________________________________________________
FritzBox as Router, that gets the IP4 assigned by the Internetprovider |
| ________________________________________________________|
| Vm | Vl
GS108Tv3 No2
|Trunk
Mediaconverter
Optical Fiber
Mediaconverter
|Trunk
GS108Tv3 No1
| Vm | Vl
| |_________________LAN
Cablemodem
Internet
The Test-Step that failed, showing the Problem that first has to be solved
| Vm | Vl
GS108Tv3 No1
| Vm
Mediaconverter
Optical Fiber
Mediaconverter
Cablemodem
Internet
Vm and Vl stands for the VLANs:
Vm = modem-router connection
Vl = local, including administartion of the GS108Tv3
My Guess is that the Cablemodem already uses a VLAN-ID
and so the connection is dropped, because i don't know whats
the Number and so the GS108Tv3 was not assigned to it.
schumaku
Dec 26, 2021Guru - Experienced User
Keep the Vm VLAN untagged on the trunk port(s) and on the "access" port(s).
Unlikely the Internet does come tagged from the modem, for IPTV and telephony this might be different. A potential internet VLAN config should be visible in the Fritz config in case. To figure out a potential tagged VLAN usage for the Unitymedia cablemodem, look into a Unitymedia customer forum....
How are the VLANs and the ports to connect the cable modem on the test setup (and the final with two switches) configured?
- _Karl_Dec 26, 2021Aspirant
VLAN-Name: Management VLAN
VLAN-ID 1
Portmitglieder 1, 5, genehmigtPorttyp General
Zugriffsport
QoS-Profil: Data
VLAN-Name: Kabelmodem
VLAN-ID 200
Portmitglieder 3, 7, 8 ,genehmigt
Porttyp General
Zugriffsport
QoS-Profil: Voice QOS:7- schumakuDec 27, 2021Guru - Experienced User
Ok, this would make up two individual networks, VLAN 1 and VLAN 200. VLAN 200 can only work is the PVID on these access ports would be set to PVID 200. Guessing the VLAN 1 access ports are set to PVID 1 by default.
As is, there is nothing which could make up a trunk for connecting two switches with a trunk line. For the trunk I suggest to configure either both VLANs as tagged, or keep the primary management VLAN untagged:
Switch 1, trunk port Tx:
VLAN 1, [U]ntagged, PVID 1
VLAN 200, [T]agged, -Switch 2, trunk port Ty:
VLAN 200, [T]agged, -- _Karl_Dec 27, 2021Aspirant
I did not reach the Point where i can try trunk,
i first have ti figure out, how/if i can have sucessfully 2 completly seperated Networks
on one GS108Tv3 before i buy the second one or other hardware.
So the Start-Question is: how can i set up the GS108Tv3
so that the second Network will behave as needed,
in betwen Cablemodem and Router?
A stupid switch means no Problem betwen Cablemodem and Router. So how can second Network on the GS108Tv3 behave as good as that?
