hacesoft
Dec 08, 2019Tutor
ACL rules
Good evening, i have 4 VLANs for the switches. I played with ACL rules and I was not successful. I always blocked my entire switch perfectly with the first rule. Information I draw from : - u...
- Dec 11, 2019
Hi hacesoft,
Please following the configuration below:
2.VLAN 11 perimt access internet and special address camera _1 / camera_2 , Right ?
Configuration ip acl "VLAN11"
permit destination address 192.168.20.20 --- permit specail address can access form vlan 11
deny destination subnet 192.168.20.0 0.0.0.255 --- deny 192.168.20.0/24 subnet
deny destination subnet 192.168.30.0 0.0.0.255 --- deny 192.168.30.0/24 subnet
permit any any ---- permit access internet and other ip address
bind your vlan11 port inbound
3.VLAN 20 permit access all vlans and no permit access internet,
you just can delete 192.168.20.0(vlan 20) static-route on your Route
4.VLAN 30 only permit access internet
permit any any
bind your vlan30 port inbound
Notes:
Please see attachment examples about ip acl
kevin_hong
Dec 09, 2019Apprentice
Hi hacesoft,
Welcome to community,
Let's clarify your request one by one.
1. Management switch: Only special ip address can login and management switch
--- you can set access control, then no other address is accessible
2.Disable access to special address from VLAN 11 to VLAN 20, Right ?
--- i need more detail information about it. such as deny vlan 11 ipadd 192.168.11.10 access vlan 20 192.168.20.20.
Please provide more detailed requirements for acl
Thank you
- hacesoftDec 09, 2019Tutor
Good evening,
in the attachment I send a picture describing how I want to configure my home network.
Perhaps it is more visual than a verbal description ...
- kevin_hongDec 09, 2019Apprentice
Hi hacesoft,
Thank you for your feedback.
First, Let's clarify your needs.
1.Only one pc can access and management your switch(You don't need a configured vlan 40)
--- you can set access-control on your switch
2.VLAN 11 perimt access internet and special address cancea_1 / cancea_2 , Right ?
Are these correct ? Did i miss anything?
- hacesoftDec 10, 2019Tutor
Good evening,
almost everything is right, but the stimulus difference is that I want the VLAN20 too.
Otherwise you understand it well from the drawing.
